kc24
Jan 28, 2025Aspirant
Netgear c7000v2
Hi Bare with me - this is a little of my area of understanding. I just moved and I have a Netgear c7000v2 that is about a year old. I was using it for a cable modem/router with Xfinity at ...
kc24
Thanks ! Not the answer I was hoping for - but good to know and not be chasing ghosts.
Jan 28, 2025Guru - Experienced User
The only one thing you could do is to ethernet connect the modem to a host router after you configure the modem for a Faux AP Mode. Could use the modems wifi as a separate signal while ethernet connected to a host router.
