augustineddiaz's avatar
Jul 08, 2020
netgear c7100v attempted to change PS4 to NAT1 by changing it to default DMZ
I attempted to change router setting to make my PS4 NAT1 instead of current settings of NAT2
I made a change to my router DMZ settings and caused issues
i logged into my router navigated to the lacation below and and added IP address 192.168.0.23 (the address of hard wired PS4)
Select ADVANCED > Setup > WAN Setup. Select Default DMZ Server. Type the IP address.
I checked the box for Default DMZ Server and changed the IP address to 192.168.0.23
then i selected reboot, the router rebooted and when it finished I was unable to connect to wifi or logintpo the router
I then had to restore to defaul, dissconnect power, wait 3 minutes, plug in power put pin in reset hole for 7 seconds, now i can connect to wifi and I logged back into the router with my PC the new DMZ Ip address 192.168.0.23 is still there,
How do i change the Nat setting for the PS4 and reverse the DMZ ip addess back tgo default
I made this change watcing a video that showed assinign DMZ would change the NAT setting to 1
1 Reply
  • FURRYe38's avatar
    The only way to get NAT1 on PS is to change the modems mode from router mode to modem only mode. Otherwise NAT2 will always be seen when a router is in the middle between the modem and PS.
