NighOwl
Aug 02, 2022Aspirant
Netgear C7100V Nighthawk AC1900 WiFi Cable Modem Router - password
Needing help from the community. I have a older C7100V. I need to change the SSID from the default. I tried to log into the router (192.168.0.1) and provided my serial number. But asks for 2...
- Aug 02, 2022
Enjoy. 📡
Aug 02, 2022Guru - Experienced User
Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to routerlogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
NighOwl
thanks appreciate it
- FURRYe38Aug 02, 2022Guru - Experienced User
Enjoy. 📡
