bosskey19
Jan 11, 2018Aspirant
Netgear C7100v Xfinity Gaming Lag
Hi, I had a question regarding my internet connection. I recently had Comcast Xfinity installed at my residence and we use the Netgear C7100V Gateway to connect to the service. We have the blast pack...
vkdelta
Jan 11, 2018NETGEAR Employee Retired
your DS power levels are too high but that probably is not causing any problems. you should add a attenuator to reduce the DS and increase the US slightly. probably 6dB pad.
Have you tested it wired?
Have you tried bridge mode with just gaming PC? If the bridge mode latency is same, then it is Comcast Core network adding into delays.
Do you have any one running bit-torrent in home?
- bosskey19Jan 11, 2018Aspirant
Hi vkdelta,
Thanks for your response! I always play on wired for the most part whenever I play the Xbox and I have not tried the bridge mode via PC just yet. Just to clarify, that is through the network connections, where I'll connect the Xbox to the PC's LAN port right? I'll test it tonight if so, and will let you know the results.
I've double checked to see if there are any torrent applications or programs running on the computers at home and can confirm that there are none running.
Thanks!
- vkdeltaJan 11, 2018NETGEAR Employee Retired
turn C7100V to bridge mode and JUST CONNECT ONLY 1 (ONE) device which is your gaming PC.
you would not be able to connect multiple devices in bridge mode.
this is to prove pure bridge mode latency.
then once your test is done, convert it back to Gateway mode (or known as router mode), test it again.
Ideally tests are around same time to avoid peak vs non-peak differences.
also, try to do this test in off-peak for clear data.
Thank you for the clarification - I'll try it out!
