csandoval1994
May 13, 2019Aspirant
Netgear C7800 Dual Band Issues
I have a Netgear C7800 that I bought about a tad bit over a year ago. Long story short, the dual-band modem router has had a major issue sometime mid lifetime of ownership. The 2.4GHz connection can ...
csandoval1994
May 24, 2019Aspirant
Firmware is the latest version and before you may possibly ask, no I can not downgrade to a previous version since ISP will not do so and modem offers no way of manually doing so.
Channels have been changed to every single one possible and I have already checked what channels my neighbors are using with a third party application. As for how many neighbors I have around with a wifi signal would be about 3-4 depending in area of my house but from where my modem is set up, only three are available excluding mine.
Attempted to disable WPA and had no success.
As mentioned in my post, a device can connect to the 2.4GHz connection, but the band does not give off any internet what so ever. For a deeper clarification: phones, tablets, any device that connects, once password is entered, all devices will give an error of no internet connection.
Factory reset has been done multiple times and the same result is give. It returns to the same old "no internet connection" on any device that connects to it.
Appreciate the help and questions.
May 24, 2019Guru - Experienced User
Yes we know you can't downgrade modems nor upgrade them. ISPs do that.
Sounds like this unit needs to be RMAd is all. I'm sure NG can help you out:
https://www.netgear.com/mynetgear/registration/login.aspx
If anything, you can change the C7800 from gateway router mode to modem mode only and still use the modem portion of the C7800. It's how I'm using mine currently. Get you self a external router. The R7800 would match up well. Something to reivew. I would ask for an RMA though.
Good Luck.
