bohurt
Jun 15, 2020Aspirant
Netgear C7800 Nighthawk AC3200 WiFi Cable Modem Router intermittent Outlook issue....Me Too!
I am using Shentel as my ISP and recently upgraded to the C7800 modem. Ever since doing this I am having connectivity issues with Microsoft Exchange server. I have tried all recommendations from Micr...
Jun 15, 2020Guru - Experienced User
Are you using ISP DNS or custom DNS on the C7800?
Try setting a custom DNS on the C7800 to 1.1.1.1 and 9.9.9.9, save and apply and reboot the modem and ALL of your devices and PCs.
Be sure your PC is set for automatic IP addressing and DNS addressing.
bohurt
I was using the ISP assigned DNS but tried entering these manually and get the same results. I am sure whatever is going on is specific to this Netgear modem since it worked fine with my ISP on my old surfboard modem and my email connects perfectly fine when I put my computer on any other network with a different modem. Thanks for trying...
- FURRYe38Jun 15, 2020Guru - Experienced User
Something to contact the ISP about and see if they have any known problems with this modem and users reporting outlook email problems. If not, make contact with NG support.
- bohurtJun 15, 2020Aspirant
Thanks! My ISP has not been helpful since I own the modem and don't pay them a rental fee. I am awaiting the response from NG support as we speak. I found several threads on here with the same issue so I was just hoping someone on here had already figured out a work around.
Ok,
Something to check while you wait on NG support.
Can you load up Mozilla's Thunderbird and configure that email program like you did for your outlook email and see if a different email program does same thing? Something to give results to NG support as well.
