TB_12
May 04, 2018Guide
Netgear C7800 Nighthawk AC3200 WiFi Cable Modem Router
I have a Netgear C7800 Nighthawk AC3200 WiFi Cable Modem Router (moderator - please add this model to the "model" drop down above). My ISP is Comcast with a 1 gigabit service and Outlook is used for...
vkdelta
May 04, 2018NETGEAR Employee Retired
have you seen any internet traffic losses or is it only outlook which runs in 5 min windows?
- TB_12May 04, 2018Guide
No traffic loss that I'm aware. If you have a command you want me to run at the DOS prompt, let me know. Thanks.
- TB_12May 11, 2018Guide
It's been a week since this was posted. Are there any commands or tests you'd like me to perform?
Thanks
- vkdeltaMay 11, 2018NETGEAR Employee Retired
you would want to confirm there are not connectivity losses at all.
in command prompt type "ping 8.8.8.8 -t"
and if you outlook not syncing, capture traffic via wireshark and private message me the capture.
- TB_12May 12, 2018Guide
Thanks. I did the ping 8.8.8.8 -t and let it run for a bit. There was no loss. Here are the results:
Reply from 8.8.8.8: bytes=32 time=39ms TTL=57
Ping statistics for 8.8.8.8:
Packets: Sent = 171, Received = 171, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 35ms, Maximum = 49ms, Average = 39ms
Control-C
^C
C:\Windows\system32>I'll download Wireshark and run it later today. Thanks again.
