TB_12
May 04, 2018Guide
Netgear C7800 Nighthawk AC3200 WiFi Cable Modem Router
I have a Netgear C7800 Nighthawk AC3200 WiFi Cable Modem Router (moderator - please add this model to the "model" drop down above). My ISP is Comcast with a 1 gigabit service and Outlook is used for...
toddeaton
Oct 05, 2018Initiate
I have the EXACT same problem. What's interesting is, I have the same OUTLOOK 365 at home with a different router and I DO NOT have a problem. ONLY at work when using this C7800 Router. I'm about to throw it out and buy a TPLINK. Has there been any conclusion to this since May?
TB_12
Oct 05, 2018Guide
The issue went to the developer. They provided a firmware fix which solved the problem. But I'm waiting for a hardware fix because the firmware fix is using the CPU to resolve what the hardware should be doing.
I'll email them now and reply to this message once I hear from them.
