yager
Jun 22, 2023Follower
Netgear C7800 Nighthawk X4s Ac3200
Is the Netgear C7800 Nighthawk X4s Ac3200 WiFi Cable Modem Router compatible with a Fiber Internet service?
Kitsap
Jun 22, 2023Master
yager wrote:Is the Netgear C7800 Nighthawk X4s Ac3200 WiFi Cable Modem Router compatible with a Fiber Internet service?
In a word, no. The C7800 is a combination cable modem and router. The only input is via a coax cable.
Your fiber service will have an Optical Network Terminal (ONT) for the termination point. Normally the ONT has an Ethernet output and you would need a router. Some ONTs are also combination devices that include a router. Depending on what part of the world you are located, common practices vary.
