adubkov's avatar
adubkov
Netgear C7800 original firmware
Hi,
I'm looking for original firmware for C7800 Nighthawk X4S. There were vulnerability detected which my modem potentially could be affected. It does not boot with kernel panic when trying to load some module. I tried to boot with both flash0.kernel0 and kernel1, with same results, means both of them could be correpted. The only way to fix it is to upload original firmware and let comcast update it, but I can not download original firmware from netgear web side because it says that IPS will take care of firmware update.
I'm not asking about firmware update. But can any of netgear employees share original firmware?
Thank you.
  • FURRYe38's avatar
    Something to ask the ISP about to see if they have the 1st version of FW to push to the modem. Again, ISPs control ALL FW updates to users cable modems or gateway modems.
    • adubkov's avatar
      adubkov
      It comes with firmware from the store so, there must be original firware available. Also IPS are not very collabarative to share anything.
      • FURRYe38's avatar
        ISPs have there own policies regarding FW. Come the DOCSIS spec. ISPs control the FW upates on cable modems. Something to talk to your ISP about.
