mario123mojica
Feb 02, 2021Tutor
netgear c7800
Hellow out there i need help i been trying to find out how to update my firmware on my C7800 — Nighthawk X4S AC3200 WiFi Cable Modem Router with no lluck can some one please help me with this. ...
michaelkenward
Feb 03, 2021Guru - Experienced User
Any reason why you think you need this? Got a problem that you want fixing?
You can't update the firmware, but any problems you see may be down to something completely different.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
- mario123mojicaFeb 03, 2021TutorThe app that I have says that my modem is out of date and requires an update but I cannot update it I don’t know how I have been trying to find out how with no luck
- FURRYe38Feb 03, 2021Guru - Experienced User
Ask your ISP about FW updates. Only ISPs can update FW on cable modems and cablem modem gateways.
FYI, some ISPs will not update FW on user owned modems.
The app that I have says that my modem is out of date and requires an update but I cannot update it I don’t know how I have been trying to find out how with no luck - antinodeFeb 03, 2021Guru
> The app that I have [...]
Which "The app" is that?
> [...] says [...]
Trust no one, I always say. On the bright side, you seem not to be
alone. For example:- mario123mojicaFeb 04, 2021TutorThe app is called Nighthawk app for my iPhone The app says that it needs to be updated
