aj5lawrence
Dec 14, 2020Follower
Netgear C7800v2
I bought my Netgear C7800 router in August to get more coverage than the last one. Every couple of weeks, the router will reset to its default factory settings, which resets the router name and passw...
Dec 14, 2020Guru - Experienced User
do you have a screen snip of your cable connections and your logs?
Your isp can send reset signals as well as coax power issues can cause resets.
remove any splitters, amplifiers, or attenuators from the line.
