bertrc
Mar 18, 2021Follower
Netgear CAX30
Netgear CAX30 I don't know if is wifi 6 o wifi 6e wep3 docsis 3.1 wifi 6e bluetooth 5.2 you can control with your handy your router without wifi6e why not vdsl 2 and ftth together with do...
Mar 18, 2021Guru - Experienced User
The CAX80 is WIFI 6 only. Doe not support WPA3. WPA3 has been compromised anyways. There is no WEP3. WEP was compromized long ago and is not used anymore.
DOCSIS is a cable service spec only. Completely different from DSL and others. WIll not included any other ISP services.
Bluetooth isn't seen or used on wifi routers. Thats mostly on iphones and bads some other IoT devices.
Review the spec sheet for the CAX80 and get informatoin on what the modem supports:
https://www.netgear.com/images//datasheet/networking/CableModems/CAX80.pdf
bertrc wrote:Netgear CAX30
wep3
docsis 3.1
wifi 6e
why not vdsl 2 and ftth together with docsis 3.1
you don't know when you do a relocate with a new flat
if you can have ftth, vdsl 2 or docsis 3.1 with your new flat
it depends of the company
maybe only docsis and ftth together
1 port ftth 10gb/s and
4 ports 2,5Gb/s
cat 6e/7
I don't need calls
You can buy another machine for voice ip and after you can connect with this router separete it is cheaper
