taellinglin
Nov 08, 2022Aspirant
Netgear CAX30
I am looking in Event Logs and see errors. I have to restart the router and my server every 24 hours sometimes...it work all day and then stop working. Here is my Logs, can you help me fix these issu...
Nov 08, 2022Guru - Experienced User
got a screensnip of the cable connections page?
That helps too.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
taellinglin
Nov 09, 2022Aspirant
Does this mean I have to call my ISP to come look at the utility box or is there something I can configure on my router to fix?
- plemansNov 09, 2022Guru - Experienced User
Your cable connections page looks pretty rock solid but your event log is showing issues.
