MrG_10490312
Mar 12, 2023Tutor
Netgear CAX80 cable modem router. Router dropping connection
I purchased this Netgear CAX80 in Oct 2021. At the time a high end modem/router (+$400). I can say fairly OK for the last 17 months. However, during the last week (early Mar 2023) I've had to reset t...
MrG_10490312
Mar 12, 2023Tutor
Thank you for your quick reply ... see below my answers.
What firmware version are you on? V2.1.5.2
Are you factory resetting or just rebooting? Just Rebooting ... do you recommend "factory reset"?
Have you tried downgrading the firmware a version? No, I have not ... how do I do that?
Mar 12, 2023Guru - Experienced User
If its just rebooting, try the factory reset and do a clean install. by clean install I just mean don't reinstall using a backup in case something is corrupted in the settings.
To factory reset, push and hold reset for up to 15 seconds while powered on.
Try that first.
If it doesn't work, then we'll look at downgrading a version
- MrG_10490312Mar 14, 2023Tutor
OK, I did the factory reset 2 days. The drop out still happens but less often 1-2X per day.
I did notice that what drops out is the router (WiFI radio). The CAX80 has a WiFi radio button on the front of it. Once I noticed the signal has dropped I tried pushing that button again and surprise the signal comes back.
What still puzzles me is why the WiFi radio signal is dropping out all of the sudden?
Should we try to install a previous firmware version? Current version V2.1.5.2 Don't know how to do this, though ... instructions are appreciated 🙂
Thanks in advance for the support.
- plemansMar 14, 2023Guru - Experienced User
Not hard to downgrade. Simple download the older version, follow the manual update process and instead of using newer firmware, you use the older. then you disable automatic updates.
Worth a shot
