Cerick895
May 01, 2023Aspirant
Netgear CAX80 cable modem router
To piggy back off this. Where is the setting to disable firmware updates? I downgraded mine and it auto updates. I looked everywhere online on how to disable it.
Cerick895
May 02, 2023Aspirant
Oops looked like it created a whole new thread. I was attempting to hit reply to another thread where they were attempting to downgrade firmware.
I am aware of the modem side firmware being controlled by the ISP but there is no setting to disable firmware auto updates for the router side. I've been having some wi-fi issues since the last firmware update and after going to back 1 version seemed to fix it. After a day I noticed I started having issues again, checked the firmware, and noticed it was back to the updated version.
The manual has nothing about disabling updates. Its pages 63 and 64 of the user manual. It seems a bit silly to have the ability to downgrade if its just going to go update itself again. I just want to make sure I am not missing something here.
May 02, 2023Guru - Experienced User
The CAX modems don't have the ability to disable auto FW updates.
Are you having problems with your CAX80? If so, please describe what your experiencing.
- Cerick895May 02, 2023Aspirant
Issues are:
-Dropping internet at random times. (only happens on wifi connections, wired never drops)
It drops for a few moments then comes back (pages fail to load, video stops buffering). I initially thought it was the wifi bands competing against each other but have tried disabling each to rule that out. It happens regardless if 2g or 5g. I also notice when it drops due to my nest cameras going offline.
-Ping ponging between wifi bands.
I have disabled one band and also tried turning down transmit power on each to make sure there wasnt some conflict going on. No result. Its not a channel issue as I live out in the middle of nowhere. I do not have neighbors to contend with. No its not in front of a microwave or appliance. It sits in an office in the middle of a 1 story house.
-Range deterioration despite being in the same spot as its always has been.
I had this mode/router for about a year so it started happening during the winter. I noticed the last firmware update was dated NOV 2022. So about the same time it was released and probably when it updated.
- FURRYe38May 02, 2023Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?How do you have Basic and Advanced Wireless settings configured on the modem?
Do you have Smart Connect and AX mode enabled on the modem? Have you tried these disabled?
What devices do you have connected?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- Cerick895May 02, 2023Aspirant
-Using auto. I will give manual ones a try but since I don't have close neighbors I wouldn't figure this to be the issue.
Any Wifi Neighbors near by? If so, how many?-One at most. Very weak signal.
-No advanced settings beyond configuring DNS. I've already tried removing those.
-I tried disabling Smart Connect since it felt like a band steering issue but did not see any improvement. I have left AX mode as is since what I was able to find on it didn't sound like it would be causing my issues.
- 2 wired PC's, 1 Roku, 2 Nest cameras, Nest Doorbell, Nest Thermostat, 2 iphones, 1 ipad, and a wireless printer.
-2.1.5.2 is loaded as it auto updates to that. I was attempting to use 2.1.4.2 for the brief time it was loaded it felt like it resolved my issues but then it auto updated so could just be coincidence.
I feel like the gateway might be on its way out but since its out of warranty/rma period already and it was pricey to begin with, I was just going to put up with its issues until it dies.
