Szeki
May 18, 2016Aspirant
Netgear CG3000 cable modem/router loses WiFi configuration after power cycle
I have a Netgear CG3000 cable modem/router I got from my ISP, and about a week ago it started losing its wifi configuration after a power cycle or power outage. Doesn't matter how long is it switched...
DarrenM
May 24, 2016Sr. NETGEAR Moderator
Hello Szeki
You can try to factory reset the device see if that helps the issue. If not you may want to have the ISP swap it out may be defective as modems with cable company's get swapped from home to home all the time.
DarrenM
