mattoram
Jul 14, 2021Tutor
Netgear cm 1200 Intermittent connection
I am having problems with my internet connection getting dropped a lot somehow. I'm not very educated on how all of this works and know only the very basics. On all of my connected devices, a...
- Jul 27, 2021
Well Netgear sent out a new modem and everything has been working perfectly for about a week, so far. The event log has been completely clear with no errors.
mattoram
Jul 15, 2021Tutor
Xfinity just tested all of the lines and signals, and everything is working on their end. It looks like the modem may be the issue. Now I need to figure out if it needs to be replaced, repaired.
vkdelta
Jul 16, 2021NETGEAR Employee Retired
actually, there is noise in line which is causing T3 timeouts.
you should get internet service but it will go out momentary when there are T3 timeouts.
US power is on the higher side as well.
you can try renting the modem and almost certain will see the same issue. you can ask them to fix the problem.
