pkovacs87
May 27, 2022Aspirant
Netgear CM 500 dropping intenet
Hi, I have a CM 500 Netgear modem with a Asus AC1200 wifi router. I have called multiple times the ISP (Xfinity) and they said everything is good from their end. one of their tech was here and ch...
pkovacs87
for the problem: It is a intermittent connection problem. so when the ISP tech was here they checked all connections.
Have a snap shot of the Events Log page? done
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly. yes they check it, 2 different tech
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
none.
Check for good coax ling fittings and no kinks on the line.
no kinks in the line. it comes straight from the wall line is straight.
Be sure your using good quality RG6 coax cable up to the modem.
it is RG6 was recently changed.
Be sure to power OFF the modem for 1 minute then back ON.
done.
I just checked the modem and noticed it is quite hot. is this normal?
Thank you for helping. looks like I got the pro here.
May 27, 2022Guru - Experienced User
A bunch of criticals that the ISP needs to look into.
https://highspeed.tips/docsis-events/
Be sure there are no coax cable line splitters in the between the modem and ISP service box.none.
What about on the other side of the wall line out to the ISP service box? All cabling and such would need to be checked up to this point on the other side of the wall.
Be sure your using good quality RG6 coax cable up to the modem.it is RG6 was recently changed.
Be sure to power OFF the modem for 1 minute then back ON.done.
Should be moderately warm. Being hot could be something on the ISP line causing it to run badly.
Be sure it's in a well ventilated area. Sometimes a external small fan works wonders.
