FastEddie99
Oct 25, 2022Aspirant
Netgear CM 500 slow speed
I have a Netgear CM 500 modem with a TP-Link AC1200 modem. Both are "Certified" by Xfinity. My service is 400 mbps from XFinity. I can only get 65 mbps wireless. With a direct ethernet connection to ...
Oct 25, 2022Guru - Experienced User
What specific tplink router is it? AC1200 is a speed and not a model. And many lower spec routers tend to not have gigabit.
Also, what computer are you testing on? have you checked your wired link speed to see if its connecting at gigabit speeds.
Make sure you're using a high quality cat 5e or at least cat 6 cable.
