worle1km1025
Mar 10, 2022Tutor
Netgear CM1000 Cable modem displaying Amber Ethernet light
Good morning, Last week I upgraded my wifi router system from a R7900 to an Orbi RBK752 (Router and One Satillite). I have Xfinity 900 mbps internet connection and needed a stronger wifi signal t...
Mar 10, 2022Guru - Experienced User
did the cable change fix the issue?
You didn't put if that helped.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
worle1km1025
Mar 10, 2022Tutor
Yesterday morning I installed the new cable so for 24 hours no issues. I had first installed the Orbit Router and Satillite this past Saturday night and I first corrected the amber light issue Saturday night after turning off power to everything for a minute and powered it back on. So I am waiting to see how the new cable works as it took 4 days for the amber light to come back on previously. Currently just speed tested as I wrote this response and so far so good.
- plemansMar 10, 2022Guru - Experienced User
Here's hoping it stays working!
- worle1km1025Mar 10, 2022Tutor
Thank you for your fast response. I'll reply back within the week if there is an issue or hit the accepted solution button.
