worle1km1025
Mar 10, 2022Tutor
Netgear CM1000 Cable modem displaying Amber Ethernet light
Good morning, Last week I upgraded my wifi router system from a R7900 to an Orbi RBK752 (Router and One Satillite). I have Xfinity 900 mbps internet connection and needed a stronger wifi signal t...
Mar 10, 2022Guru - Experienced User
Here's hoping it stays working!
worle1km1025
Mar 10, 2022Tutor
Thank you for your fast response. I'll reply back within the week if there is an issue or hit the accepted solution button.
