invalidserial
Feb 27, 2020Aspirant
Netgear CM1000 Invalid Serial Number shows a Motorola Modem instead
I purchased a Netgear CM1000 DOCSIS 3.0/3.1 modem for use with my Cox Cable Internet provider and have used it since 2017 without issue. Today, I decided to increase my internet provider speed to ful...
- Feb 28, 2020
Cox Cable called back stating they wrote down the incorrect model/serial number after me reading it back to them multiple times.....
My apologies for the waste of time, but I appreciate Netgear for also looking into the issue and their helpfulness!
This matter is considered closed, thank you!
invalidserial
Feb 28, 2020Aspirant
PM Message sent, thank you!
invalidserial
- vkdeltaFeb 28, 2020NETGEAR Employee Retired
glad Cox solved it for you. They are generally better than others.
