DaveCM1000
Nov 07, 2021Aspirant
Netgear CM1000 modem. Ethernet LED light is the only one lite. Modem is powered up and online.
I have online access to the internet. I just need to know why the LED lights aren't on and how to recover. I appreciate your assistance.
Review the user manual for LED behavior information.
- DaveCM1000Aspirant
I have verified that the power cord is properly connected to the modem. I used the power supply adapter that came with the modem. The power source (outlet) is supplying power. I have power failed the modem for recovery. However, once the modem is recovered it is still only showing the Ethernet LED as lite. The Power, Downstream, Upstream and Internet lights are all off. Even with all the mentioned LED lights out, I still get connectivity to my Netgear NIghthawk Tri-Band WiFi Router (RAX70/AS6600). There is no degradation in my internet connectivity or speed. Could there be a defect in my modem that is preventing the LED lights from working properly?
Ethernet LED:
• Green. A powered-on device is connected to the Ethernet port at 1000 Mbps.
• Amber. A powered-on device is connected to the Ethernet port at 10/100 Mbps.
• Blinking green or amber. The Ethernet port is processing traffic.
• Off. No device is connected to the Ethernet port.
