eefo
Sep 28, 2020Aspirant
Netgear Cm1000 modem issue
Hello everyone, Hope everyone is doing great. So this is what happened to me. I was using this Netgear Cable modem and Xfinity called me and offered me their free modem/router to try for free for...
eefo
Oct 06, 2020Aspirant
I actually bought a new cm1000v2 and that one is working fine on old power adapter which means that the power adapter is fine its the modem it self. I haven't tried hardwiring and pinging, will try today.
And the customer support said that it cant be RMA as it the hardware it self is okay.
Oct 06, 2020Guru - Experienced User
Something to ask the forum moderator about to see how to proceed.
- eefoOct 06, 2020Aspirant
Thank you for your reply.
Hope to see this reply soon.
- vkdeltaOct 10, 2020NETGEAR Employee Retired
dont pay extra.
Please provide Case # and we should RMA it if Power adapter is correct and new one works.
Darren RMA
- eefoOct 10, 2020AspirantCase no. 43485414
Yes sir the power adapter is okay, i have plugged the new cm1000v2 with both old and new power adapters and the new modem worked on both whereas the defective modem gave me same issue even on the new power adapter.
