DeclanMiner2005
Aug 10, 2024Aspirant
Netgear CM1000 No power light but all lights except upstream light orange and upstream light red
The model is I believe a CM1000v2 And this I guessed maybe this is a code? (maybe red is 0 or 1 and amber is 1 or 0?) So, I guessed that maybe it was a error code 1011 or 0100?? I am trying to use...
Aug 11, 2024Guru - Experienced User
Is this with the ISP coax cable disconnected from the modem?
Try a different power supply that has same volts and amps?
DeclanMiner2005
Aug 11, 2024Aspirant
No, everything is original except no ISP is connected yet. The power adapter and everything is the same.
- FURRYe38Aug 12, 2024Guru - Experienced User
Disconnect the ISP coax cable then factory reset the modem.
Try a different power supply that has same volts and amps...
