DeclanMiner2005
Aug 10, 2024Aspirant
Netgear CM1000 No power light but all lights except upstream light orange and upstream light red
The model is I believe a CM1000v2 And this I guessed maybe this is a code? (maybe red is 0 or 1 and amber is 1 or 0?) So, I guessed that maybe it was a error code 1011 or 0100?? I am trying to use...
DeclanMiner2005
Aug 11, 2024Aspirant
No, everything is original except no ISP is connected yet. The power adapter and everything is the same.
Aug 12, 2024Guru - Experienced User
Disconnect the ISP coax cable then factory reset the modem.
Try a different power supply that has same volts and amps...
