mazenarawi
Jun 26, 2018Aspirant
Netgear Cm1000 not compatible with Mediacom 1Gig internet
I have upgraded my Mediacom Internet connection to 1 gig speed and based on their website http://mediacomcc.custhelp.com/app/answers/detail/a_id/29/~/customer-owned-compatible-modems for the compatib...
mazenarawi
thanks for your reply.
i don't have the Mediacom details since they have just used their own and it was the extreme brand one.
attached the connection table and the log from the Netgear CM1000
vkdelta
Jun 26, 2018NETGEAR Employee Retired
your Downstream power levels are low. Several channels go below -7dBmv.
there are lot of t3 and T4 timeouts which will cause disconnections to you.
there seems to be only 16 D3.0 SC-QAM channels. This is bit wierd since for D3.1 deployments, we would expect them to put 24 or 32 QAM channels.
Both of the above are most likely wiring or street node issue.
It does explain speed difference though. Are you 100% sure they provisioned with correct config file? Call the support center and ask them to reprovision with 1Gig Cable Modem config file (aka boot file).
- vkdeltaJun 26, 2018NETGEAR Employee Retired
typo -> It does not explain speed difference though.
- mazenarawiJun 26, 2018Aspirant
The problem is Mediacom is not giving details they say everything working from their side . and when I tell them about the modem, they say this is Netgear issue we cant do anything from their side.
this is frustrating
- vkdeltaJun 27, 2018NETGEAR Employee Retired
Is it possible for you to get Mediacom mdoem and check the connection over period of few days?
