Mrberry12
May 07, 2019Aspirant
Netgear Cm1000 Ofdm issues
Okay so im on spectrum's gig plan and it has been a nightmare of a time..... the issue i am having is i keep loosing the lock on the docsis 3.1 ofdm profile and noone can answe...
May 07, 2019Guru - Experienced User
Try a different modem to see if same thing happens or not.
- Mrberry12May 07, 2019Aspirant
i bought a Sb6800 and spectrum couldnt even get it provisioned for their gig service.... which leaves me with a spectrum modem which they lock you out of the webui so you cannot see Snr or error log
The issues are Cm-status event type code 16 and also 24 the error just cycles cuasing uncorrectables.
