Mrberry12
May 07, 2019Aspirant
Netgear Cm1000 Ofdm issues
Okay so im on spectrum's gig plan and it has been a nightmare of a time..... the issue i am having is i keep loosing the lock on the docsis 3.1 ofdm profile and noone can answe...
Mrberry12
May 19, 2019Aspirant
There was a cm status event type 5 loosing lock on ch11-17 only happened once... still after installing -10db forward path attenuator at the drop to reduce the hot signal some how the power levels are fluctuating from .9-1.5dbmv to 3-4dbmv on downstream... as far as upstream power levels i only see .3 fluctuations and all stay within the 2db of each other
also forwardpath attenuator affects 120-870Mhz so it has little to no effect on upstream.
- Mrberry12May 19, 2019Aspirant
This is the fluctuation in the downstream power signal I am talking about... so if I have a -10db forward path attenuator to reduce a hot signal what causing downstream power to further increase? Temp of the area has been high 60s and at night mid 40s will 20 degrees cause that much of a fluctuation?
