kylaris
Aug 20, 2018Aspirant
Netgear CM1000
I bought the CM1000 off eBay and It seems to be dead.
The modem is constantly blinking power (green), downstream(amber), upstream(amber), internet(amber), and solid amber network.
Is this dead ...
dem107
Feb 03, 2019Aspirant
Did you ever get this resolved? I have exactly the same issue.
- kylarisFeb 04, 2019Aspirant
After chatting with a Netgear CSR, and reading a few forum posts.
I've concluded that the modem has corrupted firmware, thus cannot be repaired without a special device.
- Nodism1125Feb 04, 2019NETGEAR Expert
Hi Kylaris,
The FW is not corrupted based on the LED pattern you stated. The devide is not activated to your cable internet service provider.
Have you tried calling your service provider and provide the Cable modem model number, Serial number and MAC address?
https://kb.netgear.com/22715/How-do-I-connect-my-NETGEAR-Cable-Modem
- dem107Feb 04, 2019Aspirant
The lights on my CM1000 are doing the same thing. It doesn't even try to sync up with RCN. RCN tech support says they never see it try to sync.
You can see the light pattern on my modem at https://youtu.be/hxHL3XHlZv0
