kylaris
Aug 20, 2018Aspirant
Netgear CM1000
I bought the CM1000 off eBay and It seems to be dead.
The modem is constantly blinking power (green), downstream(amber), upstream(amber), internet(amber), and solid amber network.
Is this dead ...
kylaris
Feb 04, 2019Aspirant
After chatting with a Netgear CSR, and reading a few forum posts.
I've concluded that the modem has corrupted firmware, thus cannot be repaired without a special device.
Nodism1125
Feb 04, 2019NETGEAR Expert
Hi Kylaris,
The FW is not corrupted based on the LED pattern you stated. The devide is not activated to your cable internet service provider.
Have you tried calling your service provider and provide the Cable modem model number, Serial number and MAC address?
https://kb.netgear.com/22715/How-do-I-connect-my-NETGEAR-Cable-Modem
- dem107Feb 04, 2019Aspirant
The lights on my CM1000 are doing the same thing. It doesn't even try to sync up with RCN. RCN tech support says they never see it try to sync.
You can see the light pattern on my modem at https://youtu.be/hxHL3XHlZv0
- Nodism1125Feb 05, 2019NETGEAR Expert
Hi dem107,
Since you purchased the CM1000 from ebay, do you have any information if this modem used to another cable company? Once the cable modem installed to a previous ISP, the modem has a customer FW.
- kylarisFeb 05, 2019Aspirant
So once the modem has been flashed by one company's fw, then it won't take another company's fw?
"Have you tried calling your service provider and provide the Cable modem model number, Serial number and MAC address? "
Of course, that was the first thing I tried.
The CSR said, "she could see the modem but cannot connect". So a technician came by and conclude that the FW on the modem was bad.
