kylaris
Aug 20, 2018Aspirant
Netgear CM1000
I bought the CM1000 off eBay and It seems to be dead.
The modem is constantly blinking power (green), downstream(amber), upstream(amber), internet(amber), and solid amber network.
Is this dead ...
dem107
Feb 04, 2019Aspirant
The lights on my CM1000 are doing the same thing. It doesn't even try to sync up with RCN. RCN tech support says they never see it try to sync.
You can see the light pattern on my modem at https://youtu.be/hxHL3XHlZv0
Nodism1125
Feb 05, 2019NETGEAR Expert
Hi dem107,
Since you purchased the CM1000 from ebay, do you have any information if this modem used to another cable company? Once the cable modem installed to a previous ISP, the modem has a customer FW.
