kylaris
Aug 20, 2018Aspirant
Netgear CM1000
I bought the CM1000 off eBay and It seems to be dead.
The modem is constantly blinking power (green), downstream(amber), upstream(amber), internet(amber), and solid amber network.
Is this dead ...
dem107
Feb 05, 2019Aspirant
The manual says the default IP address is 192.168.100.1. Is that incorrect?
Nodism1125
Feb 05, 2019NETGEAR Expert
Oops my mistake :). The Correct IP address 192.168.100.1.
- dem107Feb 05, 2019Aspirant
I connected my computer directly to the modem and set my computer's IP address to 192.168.100.2. The modem doesn't respond.
- Nodism1125Feb 05, 2019NETGEAR Expert
Can you ping the cable modem IP address?
I can't ping it. It doesn't seem like the interface on the modem is up at all. My computer doesn't even show a working Ethernet connection.
