goldin
Apr 08, 2022Aspirant
Netgear CM1000v2 | Periodic packet loss, errors within modem logs, reset complete and router swapped
Hey Everyone, Appreciate the help in advance. We have been having issues with our internet the past 4 days and have been working to get to the source of the issue. This is our home network and th...
goldin
Hey All,
After the ISP reset, all looked good and we had about 4 hours of consistent connection. Following the 4 hours of consistent internet, we then both received disconnection errors in the respective games we were playing and had around 30 seconds of extremely high packet loss. This is what was shown in the logs as soon as the issues began.
It's odd, the issues seem to always start with this line: Notice (6) - US profile assignment change. Once it goes through a few of these, it seems the T2, T3, and T4 errors begin to show up and we both become plagued with packet loss for 10-30 seconds. Any help would be greatly appreciated!
| Time | Priority | Description |
| 2022-04-08, 20:57:36 | Critical (3) | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:57:18 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:56:24 | Critical (3) | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:56:15 | Notice (6) | CM-STATUS message sent. Event Type Code: 6; Chan ID: 5; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:56:14 | Critical (3) | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:55:44 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 11 13; New Profile: 10 13.;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:55:25 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:55:22 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:54:31 | Critical (3) | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:54:00 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:53:56 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:52:21 | Critical (3) | No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:51:52 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 10 13; New Profile: 11 13.;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:50:01 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 11 13; New Profile: 10 13.;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 20:47:54 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 10 13; New Profile: 11 13.;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 17:57:04 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 17:09:44 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 17:04:57 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 16:58:12 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 16:56:50 | Notice (6) | US profile assignment change. US Chan ID: 8; Previous Profile: 13; New Profile: 10 13.;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
| 2022-04-08, 16:56:46 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; |
Apr 09, 2022Guru - Experienced User
the ISP needs to check your line. The logs are indicating line issues and if you've done everything you can inside the home, then they're up to check external to the home. Reason it might work for a bit is a reset/reboot can have the modem connecting to different channels and those not have issues. But those channels change depending on the cmts and if it changes to ones that do have issues on them, then you'll see the problems.
- goldinApr 09, 2022Aspirant
Thanks so much for the help! These are the most recent results following a day of around 3 ping spikes resulting in temporary outages. I am guessing this supports more of what you mentioned with the ISP needing to visit the lines?
2022-04-09, 18:30:07 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 18:29:43 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 18:28:16 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 18:28:00 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 18:26:31 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 18:26:12 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 18:24:43 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 18:24:25 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 18:23:34 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 13:49:30 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 13:48:03 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 13:47:45 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 13:46:18 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 13:45:52 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 13:45:01 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 13:44:37 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; 2022-04-09, 13:43:10 Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=9c:c9:eb:87:8b:28;CMTS-MAC=00:17:10:9d:3c:10;CM-QOS=1.1;CM-VER=3.1; Ch Lock Status Mod Channel ID Freq Power SNR Unerrored Correctable Uncorrectable
1 Locked QAM256 1 507000000 Hz -2.4 dBmV 40.3 dB 3496619053 1932 678
2 Locked QAM256 2 513000000 Hz -2.2 dBmV 40.7 dB 3496624797 1940 625
3 Locked QAM256 3 519000000 Hz -1.6 dBmV 41.0 dB 3496622841 1724 708
4 Locked QAM256 4 525000000 Hz -1.2 dBmV 41.2 dB 3496620086 1961 575
5 Locked QAM256 5 531000000 Hz -1.0 dBmV 41.2 dB 3496631593 2022 736
6 Locked QAM256 6 537000000 Hz -1.0 dBmV 41.3 dB 3496630116 2212 721
7 Locked QAM256 7 543000000 Hz -1.0 dBmV 41.3 dB 3496642382 1951 856
8 Locked QAM256 8 549000000 Hz -1.4 dBmV 41.2 dB 3496650800 1807 909
9 Locked QAM256 9 555000000 Hz -1.1 dBmV 41.5 dB 3496638133 1727 798
10 Locked QAM256 10 561000000 Hz -0.8 dBmV 41.6 dB 3496648831 1715 803
11 Locked QAM256 11 567000000 Hz -0.8 dBmV 41.5 dB 3498407996 1524 845
12 Locked QAM256 12 573000000 Hz -1.1 dBmV 41.6 dB 3498407437 1411 735
13 Locked QAM256 13 579000000 Hz -0.8 dBmV 41.6 dB 3498384206 1551 731
14 Locked QAM256 14 585000000 Hz -0.7 dBmV 41.8 dB 3498412196 1344 731
15 Locked QAM256 15 591000000 Hz -1.2 dBmV 41.5 dB 3498415329 1326 639
16 Locked QAM256 16 597000000 Hz -1.3 dBmV 41.3 dB 3498427697 1175 694
17 Locked QAM256 17 603000000 Hz -0.9 dBmV 41.6 dB 3498428068 1091 729
18 Locked QAM256 18 609000000 Hz -1.2 dBmV 41.5 dB 3498434066 1225 624
19 Locked QAM256 19 615000000 Hz -1.4 dBmV 41.5 dB 3498425686 1006 678
20 Locked QAM256 20 621000000 Hz -1.3 dBmV 41.0 dB 3498438376 972 739
21 Locked QAM256 21 627000000 Hz -1.5 dBmV 40.8 dB 3499219885 1105 696
22 Locked QAM256 22 633000000 Hz -1.5 dBmV 41.0 dB 3499230239 1062 682
23 Locked QAM256 23 639000000 Hz -0.7 dBmV 40.8 dB 3499232469 1127 635
24 Locked QAM256 24 645000000 Hz 0.5 dBmV 42.2 dB 3499229622 1039 931
25 Locked QAM256 25 651000000 Hz 0.9 dBmV 42.4 dB 3499237377 982 935
26 Locked QAM256 26 657000000 Hz 1.1 dBmV 42.5 dB 3499241955 953 752
27 Locked QAM256 27 663000000 Hz 1.4 dBmV 42.5 dB 3499248653 811 660
28 Locked QAM256 28 669000000 Hz 1.1 dBmV 42.5 dB 3499253046 730 631
29 Locked QAM256 29 675000000 Hz 0.7 dBmV 41.8 dB 3499246352 754 576
30 Locked QAM256 30 681000000 Hz 0.6 dBmV 42.5 dB 3499254099 734 540
31 Locked QAM256 31 687000000 Hz 1.2 dBmV 42.8 dB 3499624305 726 492
32 Locked QAM256 32 693000000 Hz 1.0 dBmV 42.7 dB 3499627124 784 492
