ShankarHokie
Jan 24, 2024Apprentice
Netgear CM1100 - Less than half of 1.2Gbps Xfinity gigabit extra plan.
When I had just the Gigabit plan, I used to regularly clock 900+Mbps on my desktop connected with ethernet cable. The configuration is Netgear CM1100 modem ==> Orbi RBR50 router==> Netgear 1 gig swi...
Jan 24, 2024Guru - Experienced User
You never see anything much past 900Mpbs due to the Ports on the CM modem, RBR50 and the Switch all being max connection rated at 1000Mpbs.
Run a speed test with a ethernet connected PC connected to WAN port #1 on the CM modem with out the RBR online. Use Ooklas installable speed test app to test. Should see over 900Mpbs here.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Kitsap
Jan 24, 2024Master
Most likely you need to power down and restart your network in sequence.
1. Pull the power cord on your modem.
2. Pull the power cord on the main station of your mesh router system.
3. Power down your computers and mobile devices.
4. Take a breath.
5. Power up your modem and give it ample time to fully boot, stabilize, and connect to the internet. Look for the internet connection LED on the front.
6. Power up your router main station. Give it ample time to boot and connect to the internet. Look for the internet connection LED on the front.
7. Restart your computers and mobile devices.
When you check for throughput, use the Ookla stand alone application available in the play store. Avoid the web browser tests as they add a layer that is not necessary.
