Dkdman
Apr 06, 2025Tutor
Netgear CM1100 firmware update help
I have a netgear CM1100 modem. My internet provider, Sparklight, does NOT update my modem, how do I update the firmware since they do not. Sparklight ONLY updates equipment that a customer rents fro...
Dkdman
Apr 07, 2025Tutor
The issue I am trying to figure out is I have 1 gig though my service provider and I am only getting 500-750, through a wired connection. I had my ISP come out and check everything but they said it was all good. They will NOT do anything with my router or my modem because I don't rent the equipment from them. I checked the firmware on my router and it is up to date. My router is a TP Link AC4000 (wifi 5), so I wanted to check my modem firmware, thus the reason for this thread.
- DkdmanApr 07, 2025Tutor
I think I figured it out, why the slower speeds when wired. I turned off the firewall, malware and antivirus security features built into the router. After doing that, I was up to 910 to 930.
On a side note, I still feel that I should be able to update the firmware on my modem, just like I can update it on my router! Since my ISP won't update my modem firmware because I don't rent it from them!!
I appreciate everyones help....
- plemansApr 07, 2025Guru - Experienced User
I think we all think that but its part of the docsis spec. Half the reason is that if users could change firmware, they could change their speed tier as that's set with the modem provisioning.
Its one of the reasons you'll rarely see forum members recommend the modem/router combo devices as their firmware is locked too. (except the CAX series, the router side can be upgraded but not the modem side.
This not being able to update modems is true for all brands.
