patricia2626
Apr 27, 2019Aspirant
Netgear cm1100 with nighthawk r8000 speeds problem
I have a netgear nighthawk cm1100 and used nighthawk r8000 to get full one gig but the problem i only get 500 do I need to get ax wifi 6 router link aggression to get full gig am i doing something w...
patricia2626
Apr 29, 2019Aspirant
Idid it does give me fully the speed i paid for but i cant make wifi router internet ports at least one of them give me atleast 900 and not sure what else do i need to buy.
I only get full speed without the router and qos is off and some times streaming i get slow downs and dchp on screen.
Apr 29, 2019Guru - Experienced User
Ok So you've figured out that the CM1100, if directly connected, gives you full gig service? if this is so, your modem is giving you full speed and performing as expected. This question needs to be posted in the router forum for the R8000 instead of the modem forum. They're great at helping troubleshoot why routers aren't giving full service or having gproblems.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Make sure you include what firmware you're on for the R8000, what devices you're testing with (since a wireless device isn't going to give you full gigabit speeds). Even before reposting there's a few things I'd try.
1. Make sure you're on the most current firmware. Right now its 1.0.4.28
2. Factory reset the device and reset it up.
3. Make sure that the cables connecting are cat5e or cat6.
Here's the support page for the R8000. If your device is within the 90 days support window, you can go through netgear support directly. to do so, go to the top of the page, mynetgear, register an account and your device, and go through the support options. Between the community support pages and netgear official support, we should be able to get your speeds up.
- patricia2626Jun 06, 2019Aspirant
I got it to work there random things selected as there was a list of devices I disable and qos and monitor tracking.
- plemansJun 07, 2019Guru - Experienced User
Glad to hear you got it working!
