sjbhh
May 07, 2019Apprentice
Netgear CM1100 with Xfinity Gigabit - speed issue
Hi,
I have search the forum and found the exact same issue but was told to create my own thread. So here I am.
Situation: Runnning a CM1100 on a Xfinity Gigabit line, HW 2.02 / FW 2.01.02
May 07, 2019Guru - Experienced User
Thanks for creating your own post!
1. How many connections between your modem and where it enters the house?
2. splitters amplifiers in line?
3. Can you post a screen snip of your logs and your configuration page with upload/dowload signal strength/etc.
4. What device are you testing on? (specifics)
5. have you tried other devices?
6. have you ever gotten gigabit speeds on your connection?
sjbhh
I can not post - for some reason it is deleting my message immediately after posting
- sjbhhMay 07, 2019Apprentice
Ok - that worked. Sorry for the various posts.
1) No connections - cable goes directly to the modem.
2) No splitters or amps
3) see post above
4) Macbook Pro 2018 - Lenovo Laptop - Standard PC with Intel 8700 CPU and 32GB Ram, Samsung NVME
5) Only the three above
6) Yes, but not with this modem
