jrowlands
Mar 07, 2019Aspirant
Netgear CM1150v boot file
I have been having issues with erratic downstream speeds that will cut out completely at times up to 974mbps using Xfinity raspberry pi speed tester. I only manage to get speeds of 25mbps to 640mbps ...
- Mar 13, 2019
You do seem to have alot of t3 timeouts in your logs.
You can read about these timeouts here
https://pickmymodem.com/cable-modem-t3-and-t4-timeouts-error-messages-and-how-to-fix-them/
DarrenM
DarrenM
Mar 12, 2019Sr. NETGEAR Moderator
Are you able to post your modem logs and the power levels of the modem?
DarrenM
