anteroal
Mar 02, 2023Aspirant
Netgear CM1150V on Xfinity
I have been having problems with internet connectivity with my #CM1150V for the last couple of weeks. Speeds are all over the place, and often the service will drop off completely. When the Xfinity...
anteroal
Mar 03, 2023Aspirant
Terrible instability all day today. I'm having to use a hotspot on my phone to send this. Here's all the logs.
Mar 04, 2023Guru - Experienced User
All those Criticals and Warnings in the event logs indicate a signal line issue. The ISP needs to review those and resolve them. Have the ISP review these same logs.
- anteroalMar 04, 2023Aspirant
So this is not the cable inside the house or the modem? I just want to be clear before I call. They have sent two technicians out here and tried to say both times that the issue was in my home. Thanks again for all the help. Really appreciate it.
- FURRYe38Mar 04, 2023Guru - Experienced User
Could be.
You'd have to try another modem to see if you experience the same issues or not.
Everything on the modem and ISP side needs to be fully reviewed and resolved first.
I can order a new modem and get that in in a few days.
But, to be clear then, the logs don't necessarily point to this being a modem or line issue specifically? Is there a part of the log would be helpful for me to show to Xfinity? I just want to understand as much as possible before a technician shows up.
All those Criticals and Warnings in the event logs indicate a signal line issue. The ISP needs to review ALL those and resolve them. Have the ISP review these same logs.
