Eli38
Jan 05, 2020Tutor
Netgear CM1200 is not letting my PC to access internet.
Hello everybody, my PC is connected directly to Netgear CM1200 cable modem's port doesn't establish the internet connection for some reason. However, I don't have such problem when my PC is connecte...
- Jan 05, 2020
Eli38 wrote:
Yes, at the same time. Why is that a problem?yes, most ISP's only give a single IP address.
Some allow more than 1 but its rare and tends to business lines.
Port 1 and port 2 can be aggregated together for port aggregation. its also fairly rare in consumer routers to use.
That means, if you're not running a business line, have an ISP that allows multiple public IP addresses, or have a router that supports wan aggregation, only 1 port can be used at a time.
so for the average consumer, the cm1000 (1 ethernet port) or the cm1100 (2 ethernet ports) do everything they need.
Jan 05, 2020Guru - Experienced User
are you leaving the pc and the router connected to the modem at one time?
If so, that'd be why
Eli38
Jan 05, 2020Tutor
- plemansJan 05, 2020Guru - Experienced User
