behshad
Aug 31, 2020Tutor
Netgear CM1200 losing Internet connectivity on a daily basis
CM1200 model is losing Internet connections on a daily basis. Using Comcast Gig service. Rebooting the modem establish the connectivity back immediate but it has become a cumbersome rebooting the mode...
Aug 31, 2020Guru - Experienced User
Take a screen snip of that cable connection page and the logs. its easier to read. are you using wan appregation? if so, disable it.
behshad
Sep 02, 2020Tutor
Not using bandwidth agregation. See Snip screenshots of model status and log.
Netgear CM1200 port 1 is connecting to Netgear RAX 120 using Internet port.
- FURRYe38Sep 02, 2020Guru - Experienced User
Does the modem loose connection with out the router attached? Connect a wired PC to the modem directly.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
behshad wrote:Not using bandwidth agregation. See Snip screenshots of model status and log.
- behshadSep 02, 2020Tutor
Thanks for the suggestions:
It has been difficult to test that scenario. The modem reboots and I connect a PC directly to the modem, the performance is great for many hours. The modem stop responding to ping and loses Internet connections randomly couple of times a day. It is difficult to take out the WIFI Router and everyone in the house is working from home and dependant on WIFI connections.
No cable splitters. No cable TV either requiring the line to be split. Street Coax is terminating at a junction box through female-to-female connector #1 and then patch cable from the junction box to coax wall jack (female-to-female connection #2) and then directly to the back of the modem port#1 (port aggreation turned disabled).
I am testing that at the moment by removing the house coax wire. going to use a quality RG6 coax cable from the outside juction box directly to the back of the modem.
I will try the 1 minute. I am using an IP switch from 5GStore.com to ping the modem and DNS IP addresses continuously. If timeout for 10 seconds, the IP switch shut the power to the modem for 5 seconds and then back on. I can try to extend that to one minute.
Once the modem is rebooted, it goes through initialization and then connection are restored with fast throughput. It is puzzling why he modem stops working (no internet connection or respond to ping every 12 hours or so).
- fb894Nov 19, 2020Guide
Hi, Did you ever correct your problem? I have had the same problem for 3 months. Support has no solution. I have orbi RBR750
