Bay_Area650
Jun 18, 2019Tutor
Netgear CM1200, No IP address gaming console or router
Please help, I purchased the Netgear CM1200 to hard wire my computer, PS4 and smart TV, set Up is successful through desktop and IP address is acquired at desktop, but when connecting a smart tv, gami...
Jun 18, 2019Guru - Experienced User
Are you using the LAN ports in back for your other LAN devices. If so, then this will not work. The other LAN ports are meant for LAG or business class static IP addressing configurations for use with external routers connected. For home use, you need a wifi router connected to LAN port 1. All the other ports are disabled.
Bay_Area650
Jun 18, 2019Tutor
Yes, i am using the Lan Ports on the devices connected to the CM1200 Modem, if what you are saying is True, then i do not see how my Desktop being in port 1 and laptop being in port 3 both have internet, and acquired IP addresses. But thank you for the feed back
- FURRYe38Jun 18, 2019Guru - Experienced User
Any any rate, you need a main host router connected to the CM modem, then you'll have full access and be able to connect many devices to the router. The modem is just an interface device between the ISP service and your router that you connect devices too. The CM1200 is a nice modem. If you fully wanted to take advantage of the modem, you could get a R7960P router from NetGear and enable Link Aggregation on both the CM1200 and R7960P for some good bandwith capabilities. This works well as I tested this out for NG.
- Bay_Area650Jun 18, 2019TutorOk, Netgear needs to clarify this on their description of the device, it is advertised as being to have multiple devices connected, and LAG working on port 1 and 2 only, and supporting 4 different ISP's by having a business account, also i did attempt to set up NETGEAR - Nighthawk X6 AC3200 to it since i bought them together and was not going to use LAG, but also failed to provide an IP address to the Router, and confirmed the router is good by setting it up to a CM1000. But thanks for the replies
ALL CM modems are not routers. Just modems only. So you need a router behind the CM modem. The X6 router should work behind the 1200. Ensure you power OFF the CM and R series router at the same time then power ON the CM modem first, then the R series router. It should get a IP address. Ensure your using good quality LAN cabling between them. CAT is recommended. Disable any LAG on the 1200 prior to connecting the R series router to the 1200.
Good Luck.
