Bay_Area650
Jun 18, 2019Tutor
Netgear CM1200, No IP address gaming console or router
Please help, I purchased the Netgear CM1200 to hard wire my computer, PS4 and smart TV, set Up is successful through desktop and IP address is acquired at desktop, but when connecting a smart tv, gami...
rams01
Aug 27, 2019Initiate
jableux wrote:
Bay_Area650 wrote:
Ok, Netgear needs to clarify this on their description of the device, it is advertised as being to have multiple devices connected, and LAG working on port 1 and 2 only, and supporting 4 different ISP's by having a business account, also i did attempt to set up NETGEAR - Nighthawk X6 AC3200 to it since i bought them together and was not going to use LAG, but also failed to provide an IP address to the Router, and confirmed the router is good by setting it up to a CM1000. But thanks for the repliesI very much agree with this. The language on the data sheet for the CM1200 reads "4 Gigabit ports to connect more wired devices" and then goes on only to detail LAG in multiple places. There's no indication for how else these ports are to be used or clarification that these are in fact not supposed to be directly connected to other devices.
For reference, I'm using the CM1200 with a Google/TP-Link OnHub (only one LAN port) and a TP-Link 8-port switch for PC, Nvidia Shield TV, and Philips Hue Hub. I was very much hoping to eliminate the switch from the setup, but based on the information provided here (and not directly from Netgear), it sounds like that's not possible with the CM1200.
Wow, this sucks but makes sense. I only spent $200 for the CM1200 under the impression it could assign IPs to all 4 ports. In my mind the public IP hits my modem and from that point can assign private IPs to the router (linksys velop) and my hardwired PC. The packaging and over confident best buy employee made me think this was easily doable. Guess I'll return this high priced item and buy a cheap modem since I can't get speeds over 200mbps anyway
Aug 27, 2019Guru - Experienced User
The 1200 can assign WAN IPs on all ports. It has to be from the ISP and you have to have them give you multiple IPs on the wan side. The CM is just that, a modem only. It has no router fuction. The CM modem only passes thru WAN or Public IP addresses from the ISP only. There is no NAT or router built in here. For any home user or business user, there is external router required if your going to provice internet services to more than one device. Even if the modem is setup to pass thru WAN IPs over its 4 ports, there IPs will be different and there would need to be a router attached to each port so as to route traffic to there configured devices or services after the router.
I agree that the marketing and packaging of these modems should state more clearly and retailers and sales people need to be more understanding and upfront about these modems. I think the working and understanding of how these modems have been taking out of context and confused. Sales people are trying to make a sale and don't want to steer a customer away from a sale. I have a feeling that sales people don't relize exactly how these modems work, that this modem needs a router behind it regardless.
The CM1100/1200 work well as a home class modem and with a external router. Ive enjoyed both of mine.
Good Luck in your endeavours.
- rams01Aug 27, 2019InitiateActually on second thought I’ll just keep it since realistically everything else has an intel chipset except the 1000-1200 series which have the broadcom. I was using a CM700 and R7000P but started seeing signal issues on the CM700 and experiencing channel hopping and eventually spectrum said to fox the upstream i had to add a splitter... But with the more powerful 1200 modem my db and svr downstream are -9 and 36-41 respectively with my upstream channels all reading above the acceptable thresholds. Worth the investment to not need a splitter.
- FURRYe38Aug 27, 2019Guru - Experienced User
Yes, the 1000 thru 1200 model series are worth keeping since they are Broadcom based. I presume you do know about the Intel base modems and there known issues then.
Yes be sure there are no line splitters inbetween the ISP service box and modem. You'll be fine there. Just connect up a router to Port #1 and you'll be good. If you connect a router that supports Link Aggregation on is't WAN side, then you can enable LAG on the modem as awell then use Ports #1 and #2 for that.Enjoy. :smileywink:
rams01 wrote:
Actually on second thought I’ll just keep it since realistically everything else has an intel chipset except the 1000-1200 series which have the broadcom. I was using a CM700 and R7000P but started seeing signal issues on the CM700 and experiencing channel hopping and eventually spectrum said to fox the upstream i had to add a splitter... But with the more powerful 1200 modem my db and svr downstream are -9 and 36-41 respectively with my upstream channels all reading above the acceptable thresholds. Worth the investment to not need a splitter. - WOLFY1959Dec 01, 2019Aspirant
I also just bought the CM1200 not realizing that I could not use
2 routers ( Nighthawk R7000 & Asus Cellspot ) on this Modem
connected to 2 different ports.(Unfogivable not to mention that upfront, btw)
I do have an 8-Port Gigabit Switch ( I beleive and unmanaged one ),
would that work? Or a hub?
Both routers hooked up to the Switch/Hub to ethernet connection 1?
Thanks.
Jim
I should also mention that I do not
want to set up either router as a repeater.
One router is in the basement, the other
upstairs both set up seperately.
Thanks
- antinodeDec 01, 2019Guru
> [...] (Unfogivable not to mention that upfront, btw) [...]
Along the same line, advertising for most automobile models fails to
mention that there's only one driver's seat, steering wheel, instrument
panel, and so on.Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "LAN ports".Is this a new installation/configuration, or was this stuff
previously working in some way with some other modem, or what?> I do have an 8-Port Gigabit Switch ( I beleive and unmanaged one ),
> would that work? Or a hub?"work" as what? Connected how? Connecting it to a LAN port on the
CM1200 would be a mistake.> Both routers hooked up to the Switch/Hub to ethernet connection 1?
If that means what I think it might mean, then no.General advice: An Ethernet cable has two ends, so specify where both
go. Also, if a device has different types of Ethernet ports, then
"connected to device" is not enough detail.> [...] I do not want to set up either router as a repeater. [...]
What, exactly, does "as a repeater" mean to you?
Almost certainly, your (unspecified) ISP is providing you with one
external/public IP address, so, if you want to connect multiple devices
to the Internet, then the only thing which you should connect to your
modem would be a (one) NAT router; all your other devices should be
connected to the LAN ports of that router. (Those ports are really
parts of a small network switch, hidden inside the router). You _can_
connect a (another) network switch to any of those LAN ports.
> One router is in the basement, the other upstairs both set up
> seperately.What, exactly, does "set up seperately" mean to you? Both configured
as full-function routers? Which one is where? Where's the modem?What's the purpose of the second router? If it's to extend your
wireless-network coverage, then you might get more satisfactory results
if you configured the further-from-modem router as a wireless access
point, instead of as a full-function router. Look in the R7000 User
Manual for "Use the Router as a Wireless Access Point". (Details might
differ if you want to use the R7000 as your main (only) router, but the
picture in the R7000 manual is good.)
Also, starting your own thread for your own problem is usually more
helpful than extending some months-old thread with different details.
You can always include links to any old threads which you think might
be useful. - WOLFY1959Dec 01, 2019Aspirant
"Along the same line, advertising for most automobile models fails to
panel, and so on."
Most people may not be tech-savy enough to know, that when theinfo for this item says "4 Gigabit Ethernet Ports to connect more
wired devices" That because it doesn't have a built in router that
the said ports can only be used under certain circumstances.
But hey, I appreciate the sarcasm.
