B1ll's avatar
B1ll
Netgear CM2000 modem keeps dropping internet speed from 100 to 10 MBPS
Device: Nighthaw CM2000 modem
Firmware: V1.01.08
Service: Comcast Xfinity 100Mbps cable internet
Problem: Speed drops from around 100 to 10 or below randomly throughout the day.
Hey all, I moved to a new place and am having a problem with my internet.
What I did so far:
1. I have plugged directly into the modem and experienced it so it's not the wifi.
2. Often it helps to reset my router
3. I asked comcast to come by
-the guy went up the pole and into my house and
-he disconnected a couple of cables just in case they were causing interference and replaced something he said but nothing big
-he said there wasn't anything he could see causing it, the downstream was consistent, and occasionally the upstream looked jittery but that shouldn't be causing it (he put a ticket in with someone to look at the line and ensure nothing was wrong with it).
Any advice you can give? I make my living by making video calls so this is hurting me quite a bit.
I looked at the modem logs but don't know how to interpret them (I only hid the MAC addresses with the "x"):
Tue Nov 09 08:48:55 2021(Critical (3))SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Tue Nov 09 08:48:55 2021(Notice (6))DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Tue Nov 09 08:48:50 2021(Notice (6))TLV-11 - unrecognized OID;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Time Not Established(Notice (6))Honoring MDD; IP provisioning mode = IPv6
Time Not Established(Critical (3))No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Time Not Established(Critical (3))SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
  • I see some other data in the logs as well:
    Startup Procedure
    ProcedureStatusComment
    Acquire Downstream Channel507000000 HzLocked
    Connectivity StateOKOperational
    Boot StateOKOperational
    SecurityEnabledBPI+
    Downstream Bonded Channels
    ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
    1LockedQAM25620507000000 Hz4.7 dBmV40.7 dB00
    2LockedQAM25617483000000 Hz4.5 dBmV40.7 dB00
    3LockedQAM25618489000000 Hz4.6 dBmV40.6 dB00
    4LockedQAM25619495000000 Hz4.6 dBmV40.7 dB00
    5LockedQAM25621513000000 Hz4.7 dBmV40.8 dB00
    6LockedQAM25622519000000 Hz4.8 dBmV40.8 dB00
    7LockedQAM25623525000000 Hz5.0 dBmV40.8 dB00
    8LockedQAM25624531000000 Hz5.1 dBmV40.9 dB00
    9LockedQAM25625543000000 Hz5.0 dBmV40.8 dB00
    10LockedQAM25626549000000 Hz4.9 dBmV40.8 dB00
    11LockedQAM25627555000000 Hz4.8 dBmV40.9 dB00
    12LockedQAM25628561000000 Hz4.7 dBmV40.9 dB00
    13LockedQAM25629567000000 Hz4.4 dBmV40.7 dB00
    14LockedQAM25630573000000 Hz3.7 dBmV40.4 dB00
    15LockedQAM25631579000000 Hz2.7 dBmV40.0 dB00
    16LockedQAM25632585000000 Hz1.9 dBmV39.6 dB00
    17LockedQAM25633591000000 Hz1.8 dBmV39.8 dB00
    18LockedQAM25634597000000 Hz3.0 dBmV40.2 dB00
    19LockedQAM25635603000000 Hz3.9 dBmV40.5 dB00
    20LockedQAM25636609000000 Hz4.8 dBmV40.8 dB00
    21LockedQAM25637615000000 Hz5.3 dBmV40.9 dB00
    22LockedQAM25638621000000 Hz5.3 dBmV40.9 dB00
    23LockedQAM25639627000000 Hz5.4 dBmV40.9 dB00
    24LockedQAM25640633000000 Hz5.7 dBmV40.9 dB00
    25LockedQAM25641639000000 Hz5.9 dBmV40.9 dB00
    26LockedQAM25642645000000 Hz6.3 dBmV41.1 dB00
    27LockedQAM25643651000000 Hz6.3 dBmV40.9 dB00
    28LockedQAM25644657000000 Hz6.5 dBmV41.0 dB00
    29LockedQAM25645663000000 Hz6.8 dBmV41.1 dB00
    30LockedQAM25646669000000 Hz7.3 dBmV41.2 dB00
    31LockedQAM25647675000000 Hz6.8 dBmV40.8 dB00
    32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
    Upstream Bonded Channels
    ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
    1LockedATDMA1512016400000 Hz45.3 dBmV
    2LockedATDMA2512022800000 Hz46.3 dBmV
    3LockedATDMA3512029200000 Hz46.3 dBmV
    4LockedATDMA4512035600000 Hz46.8 dBmV
    5LockedATDMA5128039600000 Hz43.5 dBmV
    6Not LockedUnknown000 Hz0.0 dBmV
    7Not LockedUnknown000 Hz0.0 dBmV
    8Not LockedUnknown000 Hz0.0 dBmV
    Downstream OFDM Channels
    ChannelLock
    Status
    Modulation /
    Profile ID
    Channel
    ID
    FrequencyPowerSNR /
    MER
    Active Subcarrier
    Number Range
    Unerrored
    Codewords
    Correctable
    Codewords
    Uncorrectable
    Codewords
    1Locked0 ,1 ,2 ,348688000000 Hz6.8 dBmV40.5 dB1108 ~ 2987733863370318210
    2Not Locked000 Hz0 dBmV0.0 dB0 ~ 4095000
    Upstream OFDMA Channels
    ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
    1Not Locked000 Hz0 dBmV
    • plemans's avatar
      Use if for a bit and then re-run the logs. It looks like it was just ran. A bit longer period is needed. The cable connections page just shows when it was ran versus the log shows us a longer runtime.
