theguptas
Nov 26, 2024Guide
NETGEAR CM2050V and Xfinity Firmware update for higher speeds ie. 2GB down/200 up
HI Everyone, I know there are tons of older threads on the non-compatibility of the NETGEAR CM2050V with the higher speeds as xfinity/comcast upgraded their speeds If anyone from Netgear is read...
bobkoz
Nov 26, 2024Aspirant
There is a lot of finger pointing on both (Comcast/Netgear) sides, isn't there?
It appears that users are expected to use communityforums so that they can share rumors since you don't get any official info on either side.
theguptas
Nov 26, 2024Guide
Yes, unfortunately that seems to be the case
