| Time | Priority | Description |
| Fri Oct 28 11:43:23 2022 | (Warning (5)) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 11:43:21 2022 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 11:31:25 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 11:31:15 2022 | (Warning (5)) | Dynamic Range Window violation |
| Fri Oct 28 11:31:15 2022 | (Warning (5)) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 11:31:15 2022 | (Warning (5)) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 11:31:10 2022 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 11:31:05 2022 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | (Notice (6)) | Honoring MDD; IP provisioning mode = IPv6 |
| Time Not Established | (Critical (3)) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 10:22:14 2022 | (Warning (5)) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 10:22:12 2022 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 10:10:15 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 10:10:07 2022 | (Warning (5)) | Dynamic Range Window violation |
| Fri Oct 28 10:10:07 2022 | (Warning (5)) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 10:10:06 2022 | (Warning (5)) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 10:10:01 2022 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 10:09:56 2022 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:32:14 2022 | (Warning (5)) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:32:12 2022 | (Critical (3)) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:20:16 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:20:08 2022 | (Warning (5)) | Dynamic Range Window violation |
| Fri Oct 28 09:20:08 2022 | (Warning (5)) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:20:08 2022 | (Warning (5)) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:20:03 2022 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:19:58 2022 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:14:02 2022 | (Notice (6)) | CM-STATUS message sent. Event Type Code: 5; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:13:53 2022 | (Warning (5)) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:13:47 2022 | (Notice (6)) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:13:42 2022 | (Notice (6)) | TLV-11 - unrecognized OID;CM-MAC=08:36:c9:b3:55:30;CMTS-MAC=dc:eb:94:b5:45:5d;CM-QOS=1.1;CM-VER=3.1; |
| Fri Oct 28 09:12:25 2022 | (Notice (6)) | SW download Successful - Via Config file |
| Fri Oct 28 09:11:23 2022 | (Notice (6)) | SW Download INIT - Via Config file d11_v_cm2050vims_walledgarden.cm |
