Kitsap
Feb 19, 2025Master
Netgear CM2050V Modem Firmware Update to V10.01.03
Some reports earlier today out of PA, updated firmware for the CM2050V modem has been pushed. No indications this is a test case or a slow roll example. This firmware should be mid-split capable. ...
Mar 05, 2025Guru - Experienced User
Glad you FINALLY got it. Ya, been a long road. Hoping it works well.
Let us know if you see any problems.
Kitsap
Mar 05, 2025Master
I am on a legacy plan with Xfinity. With the old firmware my throughput routinely tested out at 1200/24. With the new firmware it tests out at 1200/42.
May look at changing the plan, but not in the real near term.
