Kitsap
Feb 19, 2025Master
Netgear CM2050V Modem Firmware Update to V10.01.03
Some reports earlier today out of PA, updated firmware for the CM2050V modem has been pushed. No indications this is a test case or a slow roll example. This firmware should be mid-split capable. ...
FAUguy
Mar 05, 2025Aspirant
I am in the South FL area (connected to the Pompano Beach Comcast plant) on a grandfathered Triple Play plan that has 1Gb internet.
Today my CM2050v was updated to V10.01.03.
I did a speed test and before was getting about 1180 down and 25 up. Now it is getting 1288 down and 45 up (as the Admin page now shows 1 OFDM channel is activated).
But I believe to be on a mid-split speed with the faster 200-300mbps uploads, it requires a newer plan (so my grandfather plan would have to be dropped, that I really don't want to do) and as also have to use the CM2500 or CM3000 modem (which doesn't come in a Voice eMTA version as the CM3050v was cancelled).
- Miked2Mar 05, 2025Apprentice
I am in Maryland on Comcast. My firmware has not been updated yet. I get 600 Down and 20 Up now. I tried a comcast modem some months ago and got 600 up and 100 down. Hopefully I will get upgraded soon and I should get the same as the comcast modem, I think!
- donawaltMar 24, 2025Hero - Experienced User
Miked2 what does Comcast say your plan speeds should be? Bring up the Xfinity app,, Tap Account at the bottom, then manage your plan, then scroll down to the Internet section and you'll see your download and upload speeds.
- KitsapMar 25, 2025Master
A CM2050V user in Chicago has reported receiving upload throughput consistent with Enhanced Speed Network values.
https://www.reddit.com/r/Comcast_Xfinity/comments/1iy1hzh/comment/mjqkivi/?context=3
- KitsapMar 05, 2025Master
FAUguy wrote:I am in the South FL area (connected to the Pompano Beach Comcast plant) on a grandfathered Triple Play plan that has 1Gb internet.
You are in the same spot I am. Need the eMTA voice option and currently in a grandfathered (legacy) plan. Did gain a few Mbps upload with the new firmware, but not very close to the Enhanced Speed Network values.
Going to have to make a choice, stay where I am or pay for a new plan!
As yet I have not seen any reports of users with both the new firmware and a newer non-legacy plan.
- FAUguyMar 05, 2025Aspirant
This is what it shows was downloaded:
SW Download INIT - Via Config file d11_v_cm2050vims_extremepro_c02.cm
